Recommendation for parting tool
davidblythe
The HSS Parting tool I use is not really upto the job
presume you work on the centre line,
am working slow with it and using lubricant, but it still snags esp on alloy
can you get carbide tips ones or any recomendations where i am going wrong
Knowledge
I think that the speed could go up, given that it is working in a soft material. Also, the tip of the tool can be shaped to give a sharper cutting edge.
Try it, what have you to lose?
Martin
Possibly try relieving underneath the tip.
markd232
There is nothing realy wrong with HSS parting off tools. I take it you are using it on al/alloy. If you are parting off say 30mm dia bar the speed should be about 300/400 rpm with coolant.
You should have a top rake angle of about 15 degees, front rake of about 5 degrees and about 0.5 deg side clearances (not required if you use a blade)
It also helps if the front cutting edge is ground at an angle of 5 degrees and not square. It is a bit hard to describe without sketching it out and not knowing what type/size of lathe you have.
davidblythe
Am using a blade
the lathe is a chester DB8V, any advice appreciated, still learning
http://www.chesteruk.net/store/db8_vari ... _lathe.htm
markd232
If you are using a blade about 3/4mm thick it will have side clearance already ground into it. Nice lathe by the way. Have you got a fax machine so I could send over a sketch ?
Daggs
You probably know it, but anyway but. The tool MUST be below the centreline of the piece, only just, but below.
davidblythe
Cheers Daggs
all tips appreciated
sideout
David
I don't know what condition your lathe is in, but an old trick if the headbearing is knackered is to invert the tool and run the lathe in reverse. :idea:
HSS tools are fine. Just make sure the rake angle suits the material being parted off.
Cheers,
Nigel
davidblythe
sideout wrote:David
Cheers,
Nigel
Hi Nigel
more detail here please,
cheers david
