metal bits on magnetic drain plug ?
rbgaz
when changing my oil i noticed 4 bits shiney broken metal stuck to the drain plug on looking closer its a roller off the chain this is bad right? what could happen if i keep riding it ? chain snap ?
andylaw7
yes dont ride it till youve had a look ,you will only wreck your engine totherwise .
I'd agree with that, the consequences of the chain snapping and locking your rear wheel don't bare thinking about :shock: :shock:
rbgaz
thats a bummer !! its clear blue calm skys here really wanted a ride :evil:
but cheers for the advice lads
gaz
rbgaz
p.s whats the best make of chain to buy ?
bristolmod
Iwis
Sandy Scooters had them in stock last I heard
Scootering since 1968.
rbgaz
well hav chain case of and cannot see a roller missing ? anyideas?
rbgaz
also the chain must worn out as there is 3 groves cutting into the casing above the mb chain guide u can move the chain with u hand so it easy touches the caseing?
Daggs
rbgaz wrote:well hav chain case of and cannot see a roller missing ? anyideas?
1) you're not looking hard enough
2) It's not a chain roller.
3) It's something other than a chain roller
4) it's been in there for years
5) The chain sounds like it's bolloxed, change it
6) thoroughly clean out the chaincase
sydduckett
Alright gaz, i might have a spare chain, not sure what size it is though. Bit of a bummer if you gotta strip the box.. :( but then again, i gotta do the same tommorow.....welcome to the club
sef
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 10 guests
