Stator Checks and Modifications
Swapped out a bog standard SIL stator for a modified MB one, which I'd converted for DC, and want to use the std SIL as a spare. Apart from carrying out the DC mod, I don't really know my way around the stator plate too well, so what is there that I could or should I do to it to make it more reliable or just to improve it and what checks should I make?
Ta.
J1MS
If you went and bought new enamal coated wire then re wound the lighting bobbins, fitted new leads and connectors, re-rivited all the dodgy rivets that secure the earthing points, replaced the LT coil with a Vespa one, you would have a top quality stator... And for less than the price of a BGM.
J1MS wrote:If you went and bought new enamal coated wire then re wound the lighting bobbins, fitted new leads and connectors, re-rivited all the dodgy rivets that secure the earthing points, replaced the LT coil with a Vespa one, you would have a top quality stator... And for less than the price of a BGM.
:shock: Are you serious?
Was it you that started a thread about stator rebuilding? I don't suppose you have the link?
jonny snatchsniffer
and not only that, but you can use thicker wire to get more power, just dont forget to alternate the bobbings winding
jonny snatchsniffer wrote:and not only that, but you can use thicker wire to get more power, just dont forget to alternate the bobbings winding
soulsurfer wrote:I don't really know my way around the stator plate too well...
I'm gonna need a bit more help with this methinks :?
I like the idea of this challenge but have a few questions...
Where do I get the wire?
What size wire?
How do you alternate the windings?
How many windings?
Which one is the LT coil and what do I ask for?
Here's the stator in question...
Out of interest its says Steelbird on the pickup (trash or not?), is this also known as the trigger?
Many thanks
J1MS
Yes have to agree with you. Thicker wire can be used for a dc conversion. I try to get around 60 windings per bobbin alternating Windings or reversing the position of the end wires to keep it in phase.
It's a trade off between volts and amps the wattage remains pretty much unchanged.
jonny snatchsniffer
you alternate by winding the 1st 1 clockwise then the wire goes onto the next 1 and its wound anticlockwise and so on till all 4 are done
so basicly the wire goes from the stator earth/centre tap then round all the bobbins alternating as you go then off the last coil to yer regulator
the lt coil uses much thinner wire to get a higher voltage.
dont beedspeed do a rewind service ?
you can always fit a vespa one, i had a pk stator on mine
Cheers.
I'm gonna give it a go :twisted:
I think it'll make more sense when I try it, especially as I've found the thread of the upgrade with pics from J1MS ;)
http://scooterotica.org/tempforum/viewt ... tor#p15772
If I was to increase copper wire thickness on the bobbins, what guage should I use?
