mugello 186 port map
truls221
would be much appreciated.
need not only for curiosity ;-)
cheers
Truls
truls221
Up up :)
as said would be much appreciated.
or nearly as helpful
- the distance from port top egde to barrel top edge measured with a vernier caliper just inside of the chamfer in the port openings.
cheers
Truls
Not quite what you wanted but is this any use?
Transfer timming - 123 degrees
Exhaust - 166
Blow down - 21.5
Taken from Scooter Centre catalogue.
Avantone
Tony
www.lambrettagearbox.com
truls221
a brief hint of the timings, thanks a lot!
would prefer a port map though, but I'll try to get a hand of one.
cheers
Truls
