Finless Flywheel
Bilko
Main scooter: LI150
Does anyone know who can take the fins off a flywheel?
Bilko's Oily Blog
any local engineering shop with a lathe......... :D
or just drill of the 6 rivet heads yourself and so remove whole ally fin assembly from steel flywheel.......... :D
Bilko
Main scooter: LI150
Thank you Sean. :)
Bilko's Oily Blog
red
Thought you would use these
:D :D :D
Bilko
Main scooter: LI150
Red, I'm that thick, I'd probably would have done that if Sean hadn't said to drill out the alloy part. :oops:
Bilko's Oily Blog
red
Bilko wrote:Red, I'm that thick, I'd probably would have done that if Sean hadn't said to drill out the alloy part. :oops:
No comment ;)
burridge01
make i lafff :lol: :lol: :lol:
Brighton F.C-LOL
Bilko
Main scooter: LI150
Does anyone know how much the flywheel protrudes from the mag housing after the whole fin assembly is removed?
Would appreciate it if someone could measure how much sticks out from the mag housing.
Bilko's Oily Blog
Bilko wrote:Does anyone know how much the flywheel protrudes from the mag housing after the whole fin assembly is removed?
If you are worried about clearance for a plastic fan you could always pack it out with spacers to make sure it clears the housing.
Bilko
Main scooter: LI150
Hello Coaster, no it's not for a fan, there will be no fan. But am I right in thinking from your reply that without the fins and fin housing, it doesn't protrude from the mag housing?
Bilko's Oily Blog
    Users browsing this forum: Baidu [Spider], Semrush [Bot] and 9 guests
