name this piston
just taken apart a 190 engine.
unknown background, but all looks ok
possibly needing some new rings though...
64mm bore, barrel is 94mm, so I'm guessing based upon webster's Suzuki 190 ?
anyone confirm this is a TS185 piston ?
it has IKYP and 29900 Made in Japan inside
thanks
dsc scotty
Yes!
Stokie
It looks like the later 'ER' type which has the ring pegs in the preferred position
What's the barrel like - Top and tailed by the sounds of it.
Knowledge
The link to the photo seems to have disappeared, but 29900 is one of the part numbers that Suzuki use for the TS185 pistons. In fact, 29900 is one of the later pistons, so it might well be the ER version.
Mitaka and Hi Level make good copies of the Suzuki piston, and both go beyond the Suzuki oversizes to 65.5mm and 66mm.
I hope this is helpful.
Martin
Knowledge wrote:The link to the photo seems to have disappeared.
oh yeah ~
the bike not ridden in a highly stressed way, so was just going to replace the rings.
are the TS & ER rings the same ??
Knowledge
I think so, though each ring is differs: the top ring is chamfered so the bottom ring will not fit in the top ring slot, and the top ring has to be the correct way up.
Martin
oh thanks. good tip
both rings fit in the top groove, but they are quite worn. 0.8mm ring gap
there's a little "T" on both, this faces "up" I guess...
Stokie wrote:What's the barrel like - Top and tailed by the sounds of it.
hello mate.
yeah, top & tailed as per webster book
real old school tune
    Users browsing this forum: No registered users and 22 guests
