R1 shock springs
sponge bob
- registered user
- Contact:
Just got an R1 rear shock and have removed orignal spring, what is the best weight for the new spring to be rated at ? Cheers .
I've a simler question as i have a taffspeed style rear shocker and would be interested to know what the spring rate is and can you buy others as with an r1 shocker.
it really depends what weight you are and your riding style and wether you have a cutdown or full frame and if you do alot of 2 up riding i do 3 spring rates 180,200 and 225 lbssponge bob wrote:Just got an R1 rear shock and have removed orignal spring, what is the best weight for the new spring to be rated at ? Cheers .
heres a selection of the 4 types i do if you need a spring i have several i can undercut demon tweeks price by a £1 if you need one i get mine directly from faulkners and buy 100 at a time
Hi, where would i get a c spanner to adjust the spring on these
cheers!
cheers!
Unrelated I know but can you give the springs a quick measure for me please? I'm looking for replacements for my Ape and I think size wise they'd be quite close.
there 7inches long and 2.25 wide on the insideJuan wrote:Unrelated I know but can you give the springs a quick measure for me please? I'm looking for replacements for my Ape and I think size wise they'd be quite close.
just try an independant bike shop or a moto cross place bewere though that there are several differant sizes i paid £3 for minedoggbhoy wrote:Hi, where would i get a c spanner to adjust the spring on these
cheers!
cheers guys,never new the fork lock ring c spanner fitted
what a spanner
I've settled in on the 180# - I just think it gives you more versatility with the adjustments. The stronger the spring, the less level of adjustment you'll have. I'm typically riding one up - weight about 210# and am tall so riding way at the back. The times I've ridden two-up I just give it a quick adjustment and we're good. The 225 made for a hard ride.
