Which Valves?
Boo
Hi all got tubless tyres and rims fitted to Lammy dont think theyre Scoot RS ones theyve got Sterling stamped on the rim brought them from Classic Lambretta Notts.Im thinking of replacing the valves after reading some bad reports on here about them failing and want to know which valves to use,will the ones from Demon Tweeks fit?the original valves have a rubber seal on the outide and one inside of the rim with a thread and nut on the ones from Demon Tweeks dont have the thread and nut. Any advise please.
Lambrettas are for life!
lamblast
DONT THINK THEY WILL FIT .I THINK THE HOLE DIAMETERS ARE DIFFERENT THE SORT YOU HAVE WILL BE FINE RAN THIS SORT MYSELF FOR 4 YEARS ITS THE LATER RUBBER VALVES THAT ARE FAILING
Boo
Lamblast thanks for advice :bouncyeng:
Nic
I have a few 90 degree 8mm valves if you need them.
Boo
Nic thanks for the offer mate decided to keep original valves :bouncyeng:
    Users browsing this forum: Ahrefs [Bot] and 1 guest
