lighting problem
showmenshaun
i have just got the lammy on the road but have a Sleight problem with the lights.
when i hit the brake my headlight dims and looks like i am flashing to over road uses. this has caused some car drivers to pull out on me can anyone give me some advise how i can correct this fault.
cheers for any help on this..
Are you using 6 volt or 12 volt system? Which stator plate? LED rear bulbs help but in my experience not too bright on the Li type light housing.
jonny snatchsniffer
on the 6 pole stator (no battery) the brake light is a different coil to the main lights and shouldnt affect it.
what is your set up ?
The dimming of the headlight is normal on 12v Indian electronic set ups. As Soulsurfer says, fit an LED rear lamp and the problem will go away. Just make sure you get one with LEDS sticking out to the sides as well ar to the rear.
A bonus of fitting an LED rear lamp is that you can fit a higher wattage headlamp 8-)
showmenshaun
cheers lads the led worked a treat. cheers
    Users browsing this forum: Google [Bot] and 22 guests
