Speedo Drive
Treeman
Main scooter: GP 225 TS1
Hi,
Can any one suggest a supplier who could provide a speedo drive and worm that works efficient for a reasonable amount of time? :roll:
Cheers,
Treeman
vegansydney
MBD---as far as I know they are the only ones making them to original Italian specs, in metal rather than plastic.
Treeman
Dont think they have any at the moment, only plastic ones. Tha last plastic one I had lasted 12 miles!
dirtyhandslopez
An original S1(or 2, I forget) is made out of steel;)
That's not going anywhere...
Try Martin he does the metal ones Bro.. http://www.lambrettaspareparts.com/page8.htm
Speedo drive kit E013
My plastic one you gave me is on over 500 miles.. :D
Treeman
OK, I have bitten the (speedo drive) bullet, change my view point (!) and am positive that this one (fourth in 4.5K miles) will actually work. I have decided to purchase a plastic one this time, however if it does not work its the last one I ever change it! :flaming:
Maz
vegansydney wrote:MBD---as far as I know they are the only ones making them to original Italian specs, in metal rather than plastic.
I purchased one fro MBD about a month ago, after spending months trying to make a plastic one last more than a few miles!
Cost about £20ish with P&P.
Just call them to order!
dirtyhandslopez
Aren't there a pile of S1 front hubs sitting around because of the bad backing plate problem? Steal the speedo drives and remove the drive gear from the hub out of them, they're steel, just like the MB ones.....
im sure i have a few knocking around
MarkH
I've got a few if MB are out. Same type.
    Users browsing this forum: Majestic-12 [Bot] and 1 guest
