Hub/Damper WTF?
Bilko
Main scooter: LI150
My hub nut hits damper when I brake.
What's going, what am I missing?
EDIT: I've put on new dampers in case there's some fault with them. :/
Bilko's Oily Blog
Bufficus
Are you using bottom damper brackets or proper links with studs?
Bilko
Main scooter: LI150
Links with studs.
Bilko's Oily Blog
does the shock run inline with the fork leg when you view it from the front
red ghost
Main scooter: lambretta gp150
Bilko wrote:My hub nut hits damper when I brake.
A rubber bush?
Bilko
Main scooter: LI150
The bush was ok. It came off when I was taking it off the stud.
Shocky, it seems straight. I do have a squint and my good eye is glass eye.
Bilko's Oily Blog
Oversized nuts on the front axle.? some after market ones are too big.
Bilko
Main scooter: LI150
They're dome ones. :/
Bilko's Oily Blog
I'm sure we noticed that Timbo had the same problem in France and it was down to oversized hub nuts. Forget what was done about it. Ah, on reflection it may have been the nut on his front inboard disc brake stud. :oops:
Bilko
Main scooter: LI150
That's ok Martin.
Cheers anyway. Maybe try stiffer springs.
Bilko's Oily Blog
    Users browsing this forum: Ahrefs [Bot] and 5 guests
