rear wheel wobble
sydduckett
back of my scoots rear end is all over the place, feels as though its stepping out especially on bends or when you bang it into gear while travelling. Have spun the rear wheel while on its crankcase stand and it appears to be warped but its difficult to see where the the problem is. i think its the rim so have one being delivered tomorrow (i hope) so will change tyre and stick it on the hub and see if it sorts it out.
Any ideas on what likley problem could be if not this?
ta
sef
storkfoot
Is there any play in the rear hub? Is the frame straight?
sydduckett
the frames straight and this has happened over the last few months. As i can see the wheel is warped im hoping the problem is there although it could be somewhere else and this is acsasabating it? When i took the rim off and just spun the hub it doesnt seem as bad although its still slightly out (within tollerances?).
sef
rog60
Main scooter: Indian GP200
As you say in your first post, could be the rim and....as your getting a new one, let's hope it's that simple.
P.S. You haven,t got one of those 'Ramp' brand rear hubs on have you :?: :?:
Stokie
Hopefully the new rim will sort it.
Wouldn't want to think your gearbox endplate is loose
Avantone
Why not swap wheels front to back and spin it again on it's crankcase stand (don't ride it :shock: ) - if it stops wobbling you know it's the rim, if not it's the hub/hub nut/wheel bearing/endplate/engine mounts.........
Tony
www.lambrettagearbox.com
mine did this years ago just b4 the nearsie mount snapped going round a large roundabout . get your mount shoulders checked
sydduckett
New rim now on and feels a lot better. I think theres still a bit of room for improvemnt so will look at end plate. having an op on my shoulder end of Sep so planning on doing a shake down and finishing some bits that i didnt get round to like better clutch, shortned rear runners....Gutted really as will be unable to ride for 2-3 months....roll on Mersea island
sef
    Users browsing this forum: Google [Bot], Semrush [Bot] and 96 guests
