What squish ?
sponge bob
What is the correct size of squish on a Indian stage 4 200, as i have just been told that 2.5 mm is correct as that is what i have at the moment as was about to take it down to 1.5 . Not from the most reliable source but just thought i would double check before i re build the engine.
Tosh
sponge bob wrote:What is the correct size of squish on a Indian stage 4 200, as i have just been told that 2.5 mm is correct as that is what i have at the moment as was about to take it down to 1.5 . Not from the most reliable source but just thought i would double check before i re build the engine.
checked mine when new it was 3.0 re set to 1.5 still running in only done 85miles but going strong at mo
paul
J1MS
Below 1.5 and the engine shouldn't detonate. But 3 mmis large enough to loose a little power as gas trapped at the end burns to late to make any power
J1MS
Just stripped another new SIL 200 (Donor Engine for a TS1)... But prior to taking it apart I thought I would check the squish...... It was 4.5mm... :shocking: Now that's what I call excessive
sidebottom
Playstation gamer tag: 1DDKSA4
J1MS wrote:Just stripped another new SIL 200 (Donor Engine for a TS1)... But prior to taking it apart I thought I would check the squish...... It was 4.5mm... :shocking: Now that's what I call excessive
Surely thats a record unless anyone knows different :shock:
