Hi folks
Which is the best fuel tap for a standard Rally 200 please, I’m needing to change because of leakage.
Thanks for any pointers.
Cgt75b
Tap
gaz_powell
- registered user
- Contact:
A genuine Piaggio, if you can find one.
If not SIP fast flow, that's what I've used for years with no issues.
Ok Gaz cheers, any idea what the omg ones are like?
They seem a bit more readily available in this country mate?
The shipping costs from Germany are pretty s**t now tbh
gaz_powell
- registered user
- Contact:
Try Wasp Performance, that's where I get all my Vespa stuff.
I've used OMG FF on lambrettas for years and they have been spot on., still my tap of choice.
Gaz
Gaz
I have been using an OMG on my 125T.S, it is the same frame as a rally, for a over a year now with no problems
Thanks guys really appreciate your help
Also having an issue with the carb leaking, would you guys use a little bit of sealant?
And if so what type please?
Cheers Cgt75b
Cheers Cgt75b
