GP stalls when clutch released
Northener
Main scooter: Lambretta SX200
My GP is stalling when i release my clutch, i had the engine out & after i put it back the scooter was stood some months, when I fired it up some months later & released the clutch it stalled, it was fine prior to engine removal (for engine mount renewal only).
I did notice I had not tightened the gear cables up fully (now tightened & same problem) & no the gear cables are not in the wrong position, so at a loss what is wrong here, any clues?
Mrnice71
Northener wrote: ↑Sun Jul 04, 2021 8:03 pm My GP is stalling when i release my clutch, i had the engine out & after i put it back the scooter was stood some months, when I fired it up some months later & released the clutch it stalled, it was fine prior to engine removal (for engine mount renewal only).
Have you tried pulling the clutch lever in and kicking it over until the pedal slips just to free the plates up ? I would also put some fresh gear oil in too .
Hotdog
As Mrnice71 says probably stuck clutch plates for lack of use !
mick1
Main scooter: Li Avanti 225
Gear cables wrong way round ?
mick1
just realised the poster said cables correct way round.....forget above post......can't edit it !!
Warkton Tornado No.1
i would try bump starting in a safe area with lots of spare road, then once started, pull the clutch with engine revving a bit & brake. If that doesn't free off the plates, there's something else wrong.
mick1
If it's stalling when clutch released doesn't that mean the plates are separating ok ?
Northener
Thanks for replies, I tried pulling clutch in & kicking over - no change, will take sidecasing off next weekend(hopefully) & take a look at the clutch.
Northener
Thanks again for advice, I took clutch plates out & soaked in new gear oil for a week, popped back in with the new gear oil, she's fine now.
So a seized clutch it was due to no use for some considerable time.
Northener wrote: ↑Sun Jul 25, 2021 8:42 pm Thanks again for advice, I took clutch plates out & soaked in new gear oil for a week, popped back in with the new gear oil, she's fine now.
"Should have gone to ATF"
I use it in all motors that have pass through my hands since 2014. It works well with six/seven plate race clutches on engines estimated @ 30+ BHP.
No slip, no drag. Cheap as chips. Sheds heat better than oil. Works with plates used with that cr@p ST90 etc.
The 'no drag' feature alone has saved gearboxes in my experience..
