What causes the kick start arm to start rubbing?
Davidsquaredson
Main scooter: Early Eibar Jet 200
1000kms on a fresh rebuild and the kick start arm just now starts to rub against the clutch top plate. What's most likely changed to cause this? It's a tv175 but the kick start arm is a scootopia, which I ground down a bit.
Tx
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Daggs
I'd be looking at the external shim first.
Warkton Tornado No.1
Main scooter: Lambretta SX200
What tends to get forgotten about clutches is that as they wear, the springs will continue to force the whole assembly toward the cover. This not only means the centre gets closer to the cam, thereby requiring slackening of the cable, but the top plate, bedding into the circlip will also move a Nat's in that direction & possibly even distort a little. Add to that fact that the later clutches tip to one side anyway with no centre bored clusters & you'll understand why I prefer early clutch designs.
All you can do is clean up the parts, try shimming the kickstart centre outwards & fit thick chain case gaskets, prior to refilling with ATF......
    Users browsing this forum: Ahrefs [Bot] and 2 guests
