Standard exhaust
Lambretta67
Main scooter: Lambretta L.I. 200 special
Hi
Can I use a standard exhaust on a Indian G.P. 200 engine or do I have to use a big bore. I'm sure I read somewhere that the exhaust outlet is to big for a standard exhaust . Just want to make sure before I buy a new pipe.
Lamaddict
The standard size exhaust will probably make your standard engine run smoother better and quick. I think, I’m some cases we’ve been told bigger is better but it’s not always.
Lambretta67
I thought the Indian barrel was designed for the big bore.
db67
40mm SIL Clubman I believe.
Lambretta67
So could I put a standard pipe on. The clubman pipes are too noisy for me.
db67
As long as its suitable for a 200 ;)
Lambretta67
Great .thanks. No more waking the neighbours when I go too work at 5am
dirtyhandslopez
Find an exhaust gasket that matches the exhaust port(or even use a piece of paper to take a pattern) then put it onto the exhaust flange to see if it is the same. If it's not, get the file out and make it the same. You'll know you have no obstruction then.
That's not going anywhere...
Lambretta67
Cheers. Will give that a go. Going order standard pipe from scootopia
