starting a sil lambretta after 2 years
JANFEATH
Main scooter: LAMBRETTA GP200
Hi, could anyone tell me how to go about starting my GP200 after it has been standing for 2 years.
Stebbelaner
Main scooter: Lambretta SX200
Drain all old fuel from tank and carb,check what state the inside of the carb is in and clean if necessary,check you've got a spark,add fresh fuel,allow time for the carb to fill and prod away on the kickstart - simples😉
db67
Take the plug out, check you have a spark , drop a little bit of 2 stroke down the plug hole,kick it over a few times then put the plug back in, strip & clean the carb, drain any fuel out the tank & refill with fresh petrol & then you should be good to go for a start up👍
JANFEATH
db67 wrote: Sat May 01, 2021 6:42 pm Take the plug out, check you have a spark , drop a little bit of 2 stroke down the plug hole,kick it over a few times then put the plug back in, strip & clean the carb, drain any fuel out the tank & refill with fresh petrol & then you should be good to go for a start up👍
Thanks.
JANFEATH
Stebbelaner wrote: Sat May 01, 2021 6:38 pm Drain all old fuel from tank and carb,check what state the inside of the carb is in and clean if necessary,check you've got a spark,add fresh fuel,allow time for the carb to fill and prod away on the kickstart - simples😉
Thanks.
gaz_powell
Did you get it started??
    Users browsing this forum: Google [Bot] and 10 guests
