Cylinder Identification
Hotdog
I have a 200 cylinder with the two top notches and the lug (3) but it has the inlet stud spacing of a 125-175 ! Would ii be correct in thinking this is a innocenti Lambro cylinder ?
Adam_Winstone
Sounds like it. I have a Lambro barrel that has the same characteristics; 66mm 200cc bore but 150 inlet stud spacing. Mine was fitted to a Series 3 import, many years ago.
The standard port timings are odd on these, for 3-wheeler use, so they pull ok low down but have a seriously poor ability to rev; great if you're carrying 20 sacks of potatoes or have a 25+ stone pillion.
Hotdog
Ok thanks, not a lot of good then unless I’ve go a Lambro !
Warkton Tornado No.1
Main scooter: Lambretta SX200
Hotdog wrote: Sun Apr 11, 2021 10:07 am Ok thanks, not a lot of good then unless I’ve go a Lambro !
Or porting knowledge & tools with a desire to prove success..... ;)
Adam_Winstone
^... agreed. I revised the porting of mine to allow it to rev-on a little more. However, what I did note (from memory) was that the inlet port was very thin (low) and wide, and already beyond the duration of a TV200 barrel, which surprised me... and is not what I was expecting for a barrel that is intended to produce good power at low RPM.
... a dark art!
Adam_Winstone wrote: Mon Apr 12, 2021 5:13 pm ^... agreed. I revised the porting of mine to allow it to rev-on a little more. However, what I did note (from memory) was that the inlet port was very thin (low) and wide, and already beyond the duration of a TV200 barrel, which surprised me... and is not what I was expecting for a barrel that is intended to produce good power at low RPM.
... a dark art!
Interesting. Rumours were around decades ago that a successful Group Four racer used a Lambro barrel. I'm guessing now that it might have been used in conjunction with base packing to decrease inlet duration yet raise exhaust & transfer ports especially in the likelihood of being limited by the choice of pistons available for a 66 mmish bore.
That workaround could still apply, though personally i would never use a dedicated Lambretta piston when stronger, cheaper alternatives are available.
With a head let in to the bore & some relatively simple lowering of the transfer & exhaust ports to meet the piston crown height @ BDC, it could make for a very useable set-up
Adam_Winstone
^... yep, it certainly introduces a few more options.
