cht gauge
rainbowrunner
- registered user
- Main scooter: Series 2, RT 195
- Contact:
Hi, could i ask best place to get a temp gauge, the LED type. seen a few on ebay for £43.50 but not sure if there ok for lambrettas, I,ve got the bracket for mounting it on light switch housing just need the bloody gauge now
Norrie Bodge
- registered user
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
- Contact:
CHT Gaugesrainbowrunner wrote: ↑Thu Nov 05, 2020 7:40 pm Hi, could i ask best place to get a temp gauge, the LED type. seen a few on ebay for £43.50 but not sure if there ok for lambrettas, I,ve got the bracket for mounting it on light switch housing just need the bloody gauge now![]()
https://www.trailtechproducts.co.uk/aca ... aTTO_20CHT
rainbowrunner
- registered user
- Contact:
thanks for the link Norrie
- zugbug
- registered user
- Main scooter: Lambretta LI125 S2
- Contact:
In case it helps anyone, I mounted two of mine with a small 'L' bracket from the leg shield trim cap. I also added my low fuel LED light and route the cables neatly down the gap. Works great and its nicely out of the way as I didn't want them on the handlebars.
rainbowrunner
- registered user
- Contact:
Hi zugbug, were did you order your cht gauge from and did you have to order the sensor wire seperate ? looks good what youv done.
- zugbug
- registered user
- Contact:
Hi Rainbowrunner, I bought mine through Service Racing on ebay, Clive was super helpful and told me the CHT cable was 75cm from the packet, which was not long enough for my series 2 Lambretta.rainbowrunner wrote: ↑Sat Nov 07, 2020 7:48 pm Hi zugbug, were did you order your cht gauge from and did you have to order the sensor wire seperate ? looks good what youv done.
https://www.ebay.co.uk/str/serviceracing
There were two extension lengths available at the time, either the 60cm (24") or the 120cm (48"). I checked by measuring with a bit of string routing through the frame and went for the longer 120cm one as i was just a little short with the total combined length. I do have a small bundle of wire under the toolbox, but its not a lot and its a very thin and unobtrusive cable.
For the Rev counter/Hour meter I asked the same question and was told that the sensor wire is 170cm long. You need 5cm-ish to wrap around the spark plug lead so about 165cm really. No extension was needed for the rev counter.
Hope that helps!
rainbowrunner
- registered user
- Contact:
cheers my friend, super helpful
operonalan
- Main scooter: tv200
- Contact:
What should the temperature be when running ..i. e what is normal range and what is too hot etc ? ...if running too hot what causes it ? Cheers
paul d
- registered user
- Main scooter: T5 172 Tv 240
- Contact:
The questions above have put a smile on my face and to be honest, have caused many sleepless nights for very many people including myself! Normal range for me is anything between 140c to 180c. My scoots aren't standard. 180ish when travelling slow up long hills, slow into a continuous headwind or chugging 4th in traffic or in company at slowish speeds. When it goes towards 190c or beyond I get worried. A very rare occurence. I've seen 220c on an alloy barrel and an iron barrel too now that I think of it. I think beyond 200c is danger zone but I've never seized to know for sure. If I can't stop it getting to 200c by running with choke or dropping a gear and spinning the fan quicker then I pull over, blip the engine with the choke on for a bit and pray that the temp drops. It always has except once. I just knocked off the engine. I'd lost all the head cowling screws and the cowl was held by the exhaust in no mans land. Reasons for running too hot? that's a large box of headaches. Jetting and timing are very important to get right along with a proper piston/cylinder/head set up. Crud free petrol tank with good fuel flow essential.
operonalan
- Contact:
Do you have to modify cylinder head to accommodate the sensor under the spark plug ..so it sits flat under the plug ? Eg with the trail tech model or others
