vespa t5 MK1 headset screen change
boxofbits
how do you change the screen blade on a MK1 vespa t5 had plenty of p ranges whick is a few bolts underneath for top to pop off but this just look like some self tappers do they hold all the sections together do I just undo them or can I just unclip the black Speedo bit from the top :oops:
gaz_powell
It's a while since I did a T5, but from memory yes all the self tappers out and dismantle.
Don't forget to push the speedo cable up from the bottom to give play on the speedo
