Piston 2 bore clearance for Lml 2T?
Davidsquaredson
Main scooter: Early Eibar Jet 200
Hi,
I've never worked on an lml engine before. Have the cylinder off. I can get a .229mm feeler between the piston and wall, about 2cm down from top. Its original piston, crank and cylinder.
Anyone know what the acceptable range is?
And yes ill bin the crsnk and put in a series pro fkowed crank from SIP.
Tx
David
Sent from my SM-G981W using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
