Intro
NEW MEMBER? - You must now introduce yourself here first BEFORE you can post in any other section!
Say hello and let us know a bit about you and what scooter you own, etc...THEN you will be able to post elsewhere.
oiBoy
Main scooter: Vespa P125X
Hi All
Plunging into the murky world of VESPA ownership after buying a "bargain" last year, which has sat in the shed and gathered dust since then.
Believed to be a P125Xe 1977/8 (R)
Engine VNL3M...
Chassis VNX1T
Its has no indicators in the leg shield and came with cut down side panels. I think I managed to source some 2nd hand side panels with no indicator holes, but I am not sure if I got the right ones.
Years ago I was an apprentice panel beater sprayer, so the painting and bodywork will not be a problem. It wont be my 1st rebuild either, as 10 years ago I rebuilt a FS1e.
I live in the SE not far from the continental "PIPE" and hope to rebuild the scooter through this winter and have it ready for spring 2021 as close to its original spec as possible.
Regards OiBoy
Martin20
Hi, and welcome to the forum!
