Polini 210 ALU, did your rings need filing?
Davidsquaredson
Main scooter: Early Eibar Jet 200
I’ve got 6 scooters, was working on more than one when I put my polini kit on. I have about 500kms on it. Was thinking about it today, and I can’t remember checking the rings in the cylinder. It’s the problem of jumping between several projects on the go. I probably did, but before I open it up to confirm, did people find out of the box are the rings the correct size?
Thx
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
eibargum
Mine were fine, cant tell you the gap as a mate measured them while I was porting the cases, its done a couple of 1,000 miles since without issue, had trouble with the squish being huge, got it down to 1.4mm, the circlips were a tw@7 to get on though, I run timing at 18 degrees & it sits around 320f through a SIP 2.
Davidsquaredson
eibargum wrote:Mine were fine, cant tell you the gap as a mate measured them while I was porting the cases, its done a couple of 1,000 miles since without issue, had trouble with the squish being huge, got it down to 1.4mm, the circlips were a tw@7 to get on though, I run timing at 18 degrees & it sits around 320f through a SIP 2.
I know better but just installed the kit and started running it. At 600 kms I opened it up. Rings are fine. I had same squish issue and got rid of the head gasket. This got it down to 1.4. I believe it’s up around 1.8 you get pre-ignition. My piston had too much carbon, I’m running too fat. I was doing 3% for break in, thinking of dropping down to 2%. I’m also running a SIP 2. What jetting do you have?
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
    Users browsing this forum: No registered users and 62 guests
