Damper gaiters.
10 inch Terror
Xbox live gamer tag: No.
Hi all, has anyone got rubber gaiters fitted to standard type dampers? I’ve got some MB ones I’m fitting to some slim type dampers. I’m struggling to see on which part of the dampers they should be fitted. Has anyone got a picture of theirs fitted please? Thanks in advance Pete.
gaz_powell
http://www.discodezscooters.co.uk/p/lam ... p_li_1_2_3
I can't post a picture of mine - but they are just like these
Lambretta67
Main scooter: Lambretta L.I. 200 special
Yep . That's how mine fit
10 inch Terror
gaz_powell wrote: Sat May 02, 2020 7:26 pm http://www.discodezscooters.co.uk/p/lam ... p_li_1_2_3
I tried fitting them like that, but the gaiter just slides back up the damper. I’m not too impressed with them tbh. £25 and they look like a bag of spuds.
gaz_powell
Sounds like you've got the bigger ones for standard size and not the ones for slimline dampers.
10 inch Terror
gaz_powell wrote: Sat May 02, 2020 10:09 pm Sounds like you've got the bigger ones for standard size and not the ones for slimline dampers.
When I ordered them the description said for slim type dampers. The dampers are the Scootopia re made ones. I’ll do some investigations today. Cheers mate.
db67
Return them for a refund & source some from another dealer ;)
10 inch Terror
Turns out I need the ‘Fat’ dampers. I ordered the ‘slim’ type...doh!
gaz_powell
Im after a pair of used slim ones for my dampers......if MB won't swap them !
    Users browsing this forum: Google [Bot], Semrush [Bot] and 17 guests
