Scooter running on
Shipleystevep
Hi,
What can cause a scooter to “run on” after you’ve shut the throttle? Takes a good few seconds for the refs to drop when the throttle is closed. Checked for air leaks and all sound. Thought it was the carb but stripped and cleaned. Struggling with this now.
Any ideas?
Cheers
Steve
Tractorman
Have you check the slide is closing fully, if not could the cable not returning smoothly.
Shipleystevep
Hi,
Yes revved it at the carb and forced the slide shut, still runs on ....
HxPaul
Check the choke isn't open slightly.
Scooterdude
Poor routing of the throttle cable, or cable is in need of lubrication.
mick1
Main scooter: Li Avanti 225
usually sign of an air leak.....pressure test to be sure
Shipleystevep
Checked for air leaks, that was my first thought. Not cable I’ve done it manually at the carb.
Not checked the choke. - I’ll have a look. Thanks
Scooterdude
Ok, is this something it’s always done? Or have you changed something and then it started doing it? Or is it something that’s recently developed seemingly all by itself?
firekdp
If idle does return to normal, but takes too long to do so, I'd suspect the idle mixture is too weak.
Scooterdude
Ok just tried to edit my last post but the stupid settings although allowing me to edit it but once I posted it. It doesn’t show, maybe something admin should look at? As i know it’s been brought up before.
Anyway was trying to say: Have you made sure your vent holes in the petrol cap are clear and that you’re filter on your fuel tap is clear and you’re getting a good fuel flow?
