Lumpy tickover with PHBH
FREE tuning and maintenance info, plus links to our original tuning pages that started it all off.
stand63
Main scooter: Lambretta / Eibar S2
Hi folks
Running a new build Scootopia 186 with a 28phbh with a tea strainer filter and AF clubman. Runs fine, starts fine and plug colour fine. I’ve adjusted the mix screw in and out and settled on the best spot for pick up and returning to tickover but it still remains very lumpy. It’s fine at start up with the choke on. Any ideas most appreciated
hat
Main scooter: SX150/ Mugello 186
If its ‘searching’ on tickover it might be short of fuel. Be worth putting in a bigger float valve and/ or pilot jet. What size are these now?
gaz_powell
Check pilot jet and pilot route is not blocked.....thoroughly clean the whole carb through.
Also check your tank and petrol filter aren't full of crap
stand63
Pilot jet is size 55. Carb is new and tank/filters are clean
gaz_powell
55 defo big enough pilot.
Don't bank on the carb been clean from new - when I had this it was crap in the carb and it took a couple of cleans. Tank and filter was clean
stand63
Ah right. I’ll get it off and give it a good blast through. Thanks Gaz
hat
Hows fuel flow rate into the carb?
stand63
Seems good. No restrictions
Norrie Bodge
stand63 wrote: Sun Mar 29, 2020 9:17 am Hi folks
Has engine had a leak down test?
stand63
Yep during Recent rebuild
    Users browsing this forum: No registered users and 52 guests
