Hi
I am currently upgrading my lambretta series 3
Fitting:-
Rr195 kit
Gori exhaust/Scootopia 42mm clubman
25 dellorto
Bgm 120 AC stator
Do you have any ball park setups
ie:-
Gaskets for kit ( Base )
Carb setup ( jetting needle etc )
Timing
And any other help would be appreciated
Thank you
Rt195 setup
nick b
- Main scooter: gp200and rt195
timing 17degrees ,jetting all depends on where you live an altitude .i live in a warm climate and where a 125 jet was recomended i ended up with a 117 any way good luck i have had the kit for about 4 years .28 pwk ,bgm ignition ,ancillotti exhaust starts well ,pulls well sounds great
rainbowrunner
- Main scooter: Series 2, RT 195
bgm 195
25mm carb running through air box.
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
- corrado
- Dealer
- Main scooter: Lambretta GP
Which needle? It's the 1/8 to 1/2 throttle that are the most difficult to get right because of several things over lapping, ie, needle, atomiser and slide. Most stick with the standard 40 slide as they're not cheap to replace. Commonly used needles on the PHBL are D22, 26 & 29.rainbowrunner wrote: ↑Sat Mar 28, 2020 9:35 pm bgm 195
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
rainbowrunner
corrado wrote: ↑Tue Mar 31, 2020 2:11 pmWhich needle? It's the 1/8 to 1/2 throttle that are the most difficult to get right because of several things over lapping, ie, needle, atomiser and slide. Most stick with the standard 40 slide as they're not cheap to replace. Commonly used needles on the PHBL are D22, 26 & 29.rainbowrunner wrote: ↑Sat Mar 28, 2020 9:35 pm bgm 195
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
not sure on neadle, it was in the carb from new from readspead, same as slide, told them my set up and they jetted to suit, iv,e only changed the main jet when run in from a 102 to 100
jayteemmm
- Main scooter: Lambretta TV175
Thank you for your information it is very helpfulrainbowrunner wrote: ↑Sat Mar 28, 2020 9:35 pm bgm 195
100 main
268 atomizer
choke jet 60
starter 50
BGM v4 clubman
- garry inglis
- Main scooter: ts1 230 and rb200
with the rt 195 set the bottom edge of the transfer ports level with the crown of the piston at bdcentre depending what casing your fitting to it could be 1mm base packer or 1\2mm then check your squish with the head on you want 1.2 to 1.5 no more than 1,5
