piston holing caused by exhaust design....explain please?
cezeta
i have heard that some pipes cause piston holing. how is this caused? is it a suck it out but not back in - timing kind of glitch. anyone understand this and can shed some light on it?
i have not got a specific problem......just want to look good when i explain it to someone else some day ;)
jonny snatchsniffer
can make it run lean and detonate holing the piston
cezeta
jonny snatchsniffer wrote:can make it run lean and detonate holing the piston
well thought out explanation ;)
cezeta
MMMM, no body know?
Bilko
Main scooter: LI150
I thought the sniffer of snatches replied? :?
That's the way I thought it worked.
Bilko's Oily Blog
me too.........
although i would just add that whenever swapping pipes (especially to a more efficient one).............re jetting should be done to suit.
Bilko
Main scooter: LI150
That's the way I thought it worked. :D
I've always rejetted or at least done a few plug chops. Just to make sure.
Bilko's Oily Blog
Is it possible for some pipes to cause a weak spot that's hard to dial/impossible to out :?:
cezeta
coaster wrote:Is it possible for some pipes to cause a weak spot that's hard to dial/impossible to out :?:
yes this was the line i was thinking, no disrespect chaps but i was looking for a bit more depth to the theory involving pulse timing exit tube diamiters ect.
just curioius really to what is going on to cause these problems
Have been wondering about this myself, also does the exhaust material play a part?
    Users browsing this forum: Google [Bot] and 18 guests
