TSR Evo Tail can support
Norrie Bodge
essexgp wrote: Fri Nov 08, 2019 5:32 pm
Norrie Bodge wrote: Fri Nov 08, 2019 2:07 am
essexgp wrote: Thu Nov 07, 2019 7:45 pm
Which SIP endcan do you use? as my Evo support bracket is fouling my GP side panel to
I haven’t used my TSR pipe yet m8 so not changed end can
But was informed it’s these ->. https://www.sip-scootershop.com/en/prod ... ng_20006ca
Thanks for that info but do you mean the SIP or the PM one? sorry to be thick
This one which in the description says same stud spacing as a PM
Scooterdude
I can confirm the cans sold by Chiselspeed as fitted to their exhaust range share the same stud spacing as the TSR evo.
holty
Main scooter: lambretta gp
you other option would be to alter the bracket, ive apapted one on my gp and its more or less under the end can, I do have a non standard exhaust so I had to make my own mounting on the engine, then a rubber bobbin, then cut and welded the bracket to fit between the two.
Norrie Bodge
holty wrote: Sat Nov 09, 2019 7:28 pm you other option would be to alter the bracket, ive apapted one on my gp and its more or less under the end can, I do have a non standard exhaust so I had to make my own mounting on the engine, then a rubber bobbin, then cut and welded the bracket to fit between the two.
Any piccys mate?
Hughieboy
Main scooter: Lambretta Li S2 GT186
Thanks everyone.... photos of your bracket would be great!
essexgp
Main scooter: Indian Gp200 Indian Gp Cutdown
Scooterdude wrote: Sat Nov 09, 2019 3:15 pm I can confirm the cans sold by Chiselspeed as fitted to their exhaust range share the same stud spacing as the TSR evo.
Thanks for the info
essexgp
Norrie Bodge wrote: Sat Nov 09, 2019 1:26 pm
Thanks again for the info
GTFOMWSC
The trouble is we shouldn't have to do all this they cost enough money why should we end up fixing there crap.On mine also the 2 holes for the barrell studs were not far enough apart so i had to take my old JL manifold and clamp it together with the evo one and drill them through so it would fit,i'm told this has been common on a few of them as well.TBH it's bull we don't buy them to do all this they should fit right and to make a half attempt at a rear bracket that looks and fits sh*te just shows poor quality control(unfortunately same as the SIP road 2 vespa exhausts).
the man don't give a f@@k
Hughieboy
GTFOMWSC wrote: Mon Nov 11, 2019 8:19 am The trouble is we shouldn't have to do all this they cost enough money why should we end up fixing there crap.On mine also the 2 holes for the barrell studs were not far enough apart so i had to take my old JL manifold and clamp it together with the evo one and drill them through so it would fit,i'm told this has been common on a few of them as well.TBH it's bull we don't buy them to do all this they should fit right and to make a half attempt at a rear bracket that looks and fits sh*te just shows poor quality control(unfortunately same as the SIP road 2 vespa exhausts).
Amen to that!
    Users browsing this forum: Semrush [Bot] and 0 guests
