Chaincase bolting
Tractorman
- Main scooter: Lambretta li150 special
Some think it not a good idea to use bolts instead of studs because thread wear in the chaincase. I suppose it depends on how often the chaincase side is removed
Meds1
- Main scooter: Lambretta li150s
the hard steel will wear the softer alloy threads.
The steel can cause galvanic corrosion - again damaging the casing threads. Be very careful using stainless steel- Search steel bolts in aluminium casings.
Lastly - as the threads wear they become loose and easier to cross thread.
Where I do have to use steel bolts/screws - I use low strength thread lock to try and create a barrier between the steel and alloy - like loctite 222- it’s not perfect but seems to work.
AndyM
- Main scooter: Lambretta GP125
The standard studs are high tensile steel so most of your post is not really relevant.
I’ve used black anodised steel bolts so the effects of galvanic corrosion should be minimal,
Thanks for your input though
Steveshipley
- Main scooter: Sx150
back in the 70's my pal re-tapped his chaincase to a coarser Whitworth thread and used bolts without any problem.
