Lambretta wiring problem need Advice
boxofbits
So trying to wire up my sx- the loom is a new 12v one – it seems to have a black a purple a brown and green
So a SX switch and key ignition in headset
The brown and green black are easy enough—just match them up – but where does the purple go-
I read in a manual Purple from the main loom, to purple on the ignition switch, purple is an auxiliary power feed. But the ignition switch doesn’t have a purple it has a pink (earth) yellow I think is speedo bulb or side light a blue ( no idea what blue is) orange, brown, black, I cant get the lights to work at the front—if I add the purple with the 2 blacks ( one from loom and one from ignition switch) it seem to power the back light- any ideas
orange I've done to orange of the light switch (brown to brown black to black in head set) :oops:
firekdp
You have an Indian ignition switch, on these the blue is the equivalent to purple, which is the feed for pilot lights in key position 2.
boxofbits
thanks so where do i add the purple from the main loom
boxofbits
is that now to go next to the blue
firekdp
Yes, loom purple to switch blue.
boxofbits
thanks for your help
