welding a nut onto a Mild Steel Ex for EGT
druist
i am ditching the scootrs stainless, as i have a mild steel NK expansion. I have a mig welder (135amp) and want to put my EGT meter on it and need to put a receiving nut on the downpipe. BUT what sort of nut eg metal do i get, as all look either alloy or stainless?
And i take it all welded metals need to be the same?
thanks
drew
red ghost
Main scooter: lambretta gp150
Your best bet is to use a mild steel fitting.
I made a stainless fitting as my lead-in pipe is stainless
tavspeed
not sure,but i think the probes have a 1/4" bsp thread on them you could get either a mild steel or stainless 1/4" b.s.p socket(plumbcentre or plumbers merchants should have mild steel ones) and cut it to the required length,best way to weld it would be to t.i.g it using stainless rod,you might get away with miging it using 0.6mm wire,but protect the threads in the boss to stop any spatter getting on them,cheers all.
cryogenic
Does this have to be a welded item a very simple way and cost efective is the stainless jubille clip from camlam with the cone and threads already fixed to it and you can carry a spare camlam sell them seperatley now. :baddevil:
I RAN OUT OF SICK DAYS SO I DECIDED TO RING IN DEAD
druist
Tav you are right about the 1/4 bsp thread, though it tapers. I picked up a brass one from a plumbing shop.
Though i am now wondering, DO I NEED ANYTHING? Could i just drill a hole in the pipe say just of 8mm, try and start a tiny thread with tap n die, then just twist the sender housing in as far as it goes, surround the join with some exhaust gasket red - seal??
Or wouldnt this work??
I know other ppls egt meter sender ends will differ.
Lazarus
druist wrote:i am ditching the scootrs stainless, as i have a mild steel NK expansion. I have a mig welder (135amp) and want to put my EGT meter on it and need to put a receiving nut on the downpipe. BUT what sort of nut eg metal do i get, as all look either alloy or stainless?
thanks
drew
Hi Druist sorry I cant help with your question, but I have one of my own regarding your change of pipe.
Have you compared both pipes on your scooter and if yes what were your findings regarding power/speed/etc
cheers
druist
not yet Lazarus, a few reasons for getting the NK pipe a) i kept getting problems with the ss one, leaks. b) for the past couple of years from what i have read mild steel seems to favour 2 stroke c) i can upgrade this particular pipe should i ever go the RB20 route. That said, i wont part with the scootrs one just yet as i want to compare them and i will try to remember to let you know any difference found as due to lack of garage i havent had a chance to change it yet.
druist
BTW dont suppose anyone can remember the length from the piston skirt to the probe?
cezeta
thanks
drew
simon at b race used a vespa head nut on mine. its 7mm but just needs a 8 mm tap running through it. i assume he used that as its a tall flanged nut .
TS1-200
druist wrote:BTW dont suppose anyone can remember the length from the piston skirt to the probe?
100mm I believe, by the way I am about to fit an EGT guage to mine, this may be a stupid thing to say but wouldn`t the probe cause some restriction to gas flow, or alter the flow in any way, to affect performance ?
Keep on keepin on
    Users browsing this forum: Baidu [Spider], Google [Bot] and 9 guests
