Carb fuel leak
faf
Main scooter: GP 230 Mugello
Hi all,
Dellorto phbl 25
Over night there is fuel leaking from the 2 small air holes at the bottom of the carb/mouth/venturi
could someone point me in the right direction please,float? needle?
Thanks......Steve
EddieStone
Typically the float needle. Did you turn your fuel tap off?
johnny650
EddieStone wrote: Tue Aug 20, 2019 11:12 am Typically the float needle. Did you turn your fuel tap off?
presumably not the answer he was looking for eddie :lol:
Wouldn't be the first time that I had forgotten to turn the tap off :roll:
