VBB 10" wheel conversion
davla
How do I go about a 10" wheel conversion on a 150 VBB? Do I just fit PX forks and a PX engine?
gaz_powell
I'm sure sip make an 8 to 10" conversion retaining the existing hubs
railfancwb
If you have a speedometer/odometer driven from the front wheel you will need to deal with that.
railfancwb
Rough measuring...
8” tire 39” circumference
10” tire 53” circumference
30mph with 8” tire approximately 41mph with 10” tire.
pheasant plucker
Main scooter: VBB P200
PK fork is for disc conversion. Will give small leftward misalignment (2-4mm standard). Re-fitting the mudguard is a pitfa - honestly the hardest part of going down that path.
Can get conversion hubs for VBB motor and front if discs and P200 aren’t ‘required’. Think you can even get speedo drive conversions also.
Ginch
Main scooter: Vespa 150 Super
