210 polini alloy cold start issue
Davidsquaredson
Main scooter: Early Eibar Jet 200
Sorted. The choke jet (60) is too lean. If I wound out the mix screw past 4 times it would almost catch. So I went with a 50-120 idle jet. Fat but doesn't impact the main jet much. I have mix screw turned out 3 times. Starts first kick on cold. It's raining too hard to check the rest of the throttle range but I'm on the path to glory.
Sent from my Pixel 2 using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
