Joint
cgt75b
Main scooter: lambretta
Hi dudes
Which petrol tap joint are you guys using, I'm sick to death of them breaking or vibrating themselves to bits!
Many thanks for looking
Options/opinions welcomed.
Cgt75b.
HxPaul
https://www.ebay.co.uk/itm/Petrol-Tap-B ... SwKlFcyET4
Just using a standard one like this,never had a problem.
cgt75b
Yep used those before more often than not they snap.
Thanks for that though.
I'm currently using one I bought from a well known dealer which as always has fallen to bit ffs.
Cgt75b.
Mrnice71
MB scooters do one in stainless , but if your fuel tap is not straight they will break . Guess your using a big carb on the left hand side
cgt75b
Mrnice71 wrote: Thu Jun 06, 2019 4:19 pm MB scooters do one in stainless , but if your fuel tap is not straight they will break . Guess your using a big carb on the left hand side
I wouldn't call a 25 mil dellorto a big carb!
But thanks all the same.
Cgt75b.
bazza3004
Ive never had one break. Is everything else free and easy to tirn.
cgt75b
bazza3004 wrote: Fri Jun 07, 2019 12:07 am Ive never had one break. Is everything else free and easy to tirn.
It is now bazza thanks, I've just ordered a universal joint we will see how that gets on!
Watch this space
Appreciate the help.
Cgt75b
Grumpy225
Same here. Many carb set ups with various extreme angles, never had one break. I have some original italian ones still in use on my dl with a phbh carb.
Is there something going on with the pins you’re using? Maybe they are too big and cause the joint to bind?
    Users browsing this forum: Semrush [Bot] and 10 guests
