Wits end ...and past it
nellyboyo
I`m probably a bit late to the party ...but I hadn`t seen these before ???
https://www.jockeys-boxenstop.de/Final- ... -1-3-DL-GP
Whats the idea ?? 2 shims instead of the old 1 and a dust felt pad under the retaining plate against the bearing ...???
Not that I want to spend any more money ;)
there is on most seals a fourth number denoting the spring strength. for eg 32.45.6...." 6" ! ..they usually go up to 10 ,so check that its a least a 5 ,
nellyboyo
OK tidy , I`ll check
