rt 195
lammy666
Main scooter: lambretta li 125/190 chop.
any suggestions on the type of clutch i should use on my new build rt195.
i will be running a box exhaust and a 25mm dellorto through the air box/
thanks in advance
jayteemmm
Main scooter: Lambretta TV175
Hi
I am currently building a similar setup
I also want to put a GP crank in place of the existing LI crank
I've just put a Readspeed one in my Rt 225 it's very grippy. Standard clutch was slipping on the compression just on the kickstart.
It's about 45£ for the corks, steels and springs. Done 300K running in in the last week or so and seems fine.
garry inglis
surflex plates with mb springs more than you need
Burnside
Main scooter: Lambretta TV200
Readspeed 5 plate, running them in my GT186 and GT200, been good as gold for several k miles
lammy666
cheers for the info guys
Mrnice71
Main scooter: Lambretta series 3
A 4 plate should be fine with that set up , the scootopia clutch plates are good with MB springs and rough the steel plates up a bit and putoline SAE 90 gear oil should hold
lozmondo
Done 1000,s of miles on BGM plates and MB springs on RT195, bgm pipe and 30mm carb
HxPaul
I've got a Casa 185 kit.I use a 4 plate clutch with standard springs,never a problem.
    Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 35 guests
