AFR Fresco endcan
essexgp
I know this might be a daft question but does anyone know if you can fit a different endcan to an AFR Fresco, ive measured from the top of each stud to stud and it measures 50mm is this where you measure or from the side of each stud
Thanks in anticipation
garry inglis
You measure centres and most endcans are 40mm or 45mm centre
holty
Main scooter: lambretta gp
tsr evo end cans are easy to adapt as the end that has the 3 threaded holes is 10mm thick aluminium so you can re-do the holes inbetween the original holes and re-tap
    Users browsing this forum: No registered users and 32 guests
