CHT Meter
dapper
Well, got the gauge but the lead is only about 1 metre long and far to short to reach from the headset to the cylinder head. Do they do extensions or longer leads??
PhilTH
Main scooter: Li Special
Shouldnt be hard to extend the lead. Its only 2 core wire isnt it?
dapper wrote: Tue Mar 19, 2019 4:07 pm Well, got the gauge but the lead is only about 1 metre long and far to short to reach from the headset to the cylinder head. Do they do extensions or longer leads??
Yes MB used to stock them , maybe still does or you can get online
Norrie Bodge
https://www.ebay.co.uk/itm/TrailTech-Te ... ctupt=true
bazza3004
Ring clive on this number he's a stockist for them and all related parts.
hendy
PhilTH wrote: Thu Mar 28, 2019 5:43 am Shouldnt be hard to extend the lead. Its only 2 core wire isnt it?
You can't just extend thermocouple cables or you get incorrect readings due to the tiny voltage created across the junction of the joint. Special extensions which compensate are available. Should be easy to find on eBay etc.
