Legshield spare carrier
3narf
Main scooter: 1966 Vespa 150 standard (VBB2T
Hi
I just bought a spare wheel carrier (the type that bolts to the spine and carries the spare flat against the legshields) and it needs two mounting points on the spine.
I assume I need some threaded inserts - if anyone has fitted one of these, what did you use?
Thx
gaz_powell
What model is It ? Older small frames had nuts welded inside the frame with caps over them.
Obviously yours hasn't or you wouldn't be asking.
If i were doing it id just use a riv nut, (m8) you should install them with a special tool but you can do a cheat, have a look on YouTube.
Easy job, good look.
3narf
Thanks. It's a VBB2T 'curry burner.' I'd just about come to the conclusion I'd buy the tool for the nutserts, but I guess just tightening bolts into them would pull them in... Actually, I think I have a similar tool for plasterboard inserts, maybe that would work!
gaz_powell
Did you get sorted ?
3narf
gaz_powell wrote: ↑Tue Feb 26, 2019 8:55 pm Did you get sorted ?
Hi mate
Not yet, it's quite far down the list of priorities (starting with the weak gearchange detent and the speedo drive which keeps shearing)!
I need to buy some rims first as well. When I actually do the job I'll take measurements and pics for future ref.
