Gran Turismo GT200 Big block - PHBH 30 Jetting Advice Please
Bidsy
Main scooter: Lambretta S2 Eibar Li150
Hi
Just built a Gran Turismo GT200 Big block engine and after some jetting recommendation please.
My set up is 30mm PHBH, BGM V4 clubman, 18/47 SX200 gearing.
Anybody with a similar setup?
garry inglis
145 main 55 pilot av266 an x7 second clip should get you started then check plug for fine tuning
Bidsy
Is a 145 main a little bit rich
garry inglis
It's a freshly built engine and you want it rich and for the first 500 miles you won't hit full throttle to use the main properly as I said it's a starting point as you put the miles on do plug checks but from what I've seen posted over the years with jetting for this kit they end up on 140/145 That's why you start rich
Bidsy
Thanks Garry, better order so more jets then. Cheers
Lambretta Sash
Main scooter: Lambretta TV 230
After building a few and running Gt200 on my lammy for a few years, here's my set up with TT evo pipe and not much different with Ron moss pipe. Final ratio 4.6 using close ratio box
140 main 55 pilot 40 slide x13 av268
kejj
With a v2 bgm i never went further up than 135. Now setting up with fran race and egt I am at 134. Flat out motorway speed.
________________________
http://tv175.wordpress.com/
Davidsquaredson
Main scooter: Early Eibar Jet 200
Gt200. 28mm Delly. Breathsweet foam and big rubber elbow. Pm tuning Evo pipe. Choke 60. Idle 52. Slide 40. Av268 atomizer. My main is 134. X13 needle. When I had a big big clubman (gen 1) my main was 130.
It starts 1st kick cold with the choke on and not touching the throttle.
I was not happy when I had the big box clubman on it. I could not get the mid range perfect on it. When I put the pm pipe on it, it cleaned it up perfectly. And now at 3,200 rpm I get pushed back in my seat.
Sent from my Pixel 2 using Tapatalk
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Davidsquaredson
Davidsquaredson wrote:Gt200. 28mm Delly. Breathsweet foam and big rubber elbow. Pm tuning Evo pipe. Choke 60. Idle 52. Slide 40. Av268 atomizer. My main is 134. X13 needle. When I had a big big clubman (gen 1) my main was 130.
After reading the others, I'm going to raise my main to 140 and see what it's like.
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Davidsquaredson
Bidsy wrote:Hi
Hi Bidsy,
My jet200 has the same setup. I'm trying to figure out the right exhaust to match the sx200 gear box. With the v3 bigbox, how is the behaviour going from 3rd to 4th, how is acceleration in 4th, and what's the top speed?
I've been going back over forum posts and there is a lot of discussion on this topic but I'm not finding anyone with SX gearing. I'm sure it's in there, but needle in a haystack.
Btw, I had a v1 bigbox on my scooter when I first put the GT on, but I didn't have it jetted correctly and quickly put a expansion on it that I had laying around.
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
