Brake switch 3 wires???
alanscottj
Just fitted wiring loom on a rustoration GP that I have just started and found that it has 3 wires for the rear brake light - my switch only has two. Can I still use it or do I need to either change the loom or the switch???
Many thanks in advance!
firekdp
Yes you can use the 3 hole type. When activated all 3 positions are connected, so use any of the sockets.
firekdp
Sorry read that wrong and missed the 2 second edit deadline!
So you have 3 wires in the loom at the brake switch?
mick1
Main scooter: Li Avanti 225
Makes sense.......live in from regulator giving a permanent un-switched supply for brake light, this is then joined and goes to headset, basically live in and out......the third wire will be the switched wire to the rear brake light.
So.....2 wires connected together on one side of the switch and a third wire to the other side of the switch.
alanscottj
mick1 wrote: Sat Jan 19, 2019 11:56 am Makes sense.......live in from regulator giving a permanent un-switched supply for brake light, this is then joined and goes to headset, basically live in and out......the third wire will be the switched wire to the rear brake light.
Excellent - I'll have a look and see which twi need joining - saves buying another switch!
