My ACU licence arrived about a week ago and I”m just waiting for Straightliners to release the 2019 dates. They.ll be at the usual venues but apparently there’s also some new venues for 2019 too
Little Beastie
- Main scooter: Vespa 50 Special (Rotax Proto)
Stay tuned..............
Cheers bud, it’s gonna sound awesome with that pipe should rev to around 14000 rpmscooterslag wrote: ↑Tue Dec 04, 2018 11:10 pm wow! spot on- love the pipe and back wheel set up. Paul
I”ll get a video up once I’ve dialled in the ignition and carb
The spacer arrived from Holland so I put that in place for now
And with the engingine in the correct place I could mount my pump and a few electrics
Getting there, one step nearer to start up
Trying to sort out my loom and solder things. Anyone got any tips on soldering wire to wire. I keep ending up with F@cking huge blobs of solder. I burnt my fingers three times last night too
- Main scooter: lambretta gp
when I solder wires together, flux them, tin both bits first, then more flux, hold them together and heat up with the soldering iron and they should join, add a little flux cored solder at the joining stage to help them flow, works for me, good luck.
Cheers mate, I’ll give it a go tomorrow night
New Bars arrived
Mounting brackets for different type of handlebars to be utilised as mounts for a dashboard
Temporary Dashboard Template
Alteration to the frame required to allow coolant pipe to fit
All good fun and nearly there now
PS Does anyone else have issues when trying to view pics with internet explore 11 ? If I use IE11 I cant see the pics, If I use Firefox I can. Why is that?
A friend of mine "Alex" AKA "The Car Kitchen" that also has an interest in Sprinting is doing some ally work for me, pics to follow
Dashboard Mount sorted by Alex,
Serves a purpose and I think it looks quite trick too
