177cc/si20/20
a.lo.v2
Main scooter: sx 200
Can vespa 177 kits be successfully run with si 20/20 carbs or is 24/24 a necessity. mine would be a BGM in this instance, but also like the look of VMC.
guygrrr
Main scooter: 1980 Vespa P187
You can run it with a 20/20, no problem. The benefit of the larger carb would be to provide more air flow, and correspondingly, more fuel. This allows for higher RPMs and more speed. But with the smaller carb you would expect to see better throttle response and performance off the line. This is due to better atomization of fuel at lower RPMs and smaller throttle openings.
Personally I like this thing for the 20/20 carb.
https://www.shapeways.com/product/ZFBJ7 ... arketplace
It's a velocity stack and is sort of a best of both worlds solution. It's not as good as having a bigger carb, but it will let the engine breathe a little bit better and may make an extra pony or so. And you can't beat the price.
more can do, less doodoo.
a.lo.v2
Cheers, I was not worried so much about extra performance so much as the increased mixture for cooling
    Users browsing this forum: No registered users and 65 guests
