Little Beastie
Wayne Miller
Tue Dec 04, 2018 12:21 am
Haven’t been around for some time but thought I’d stick some pics up of my new Little Beastie
More pics to follow 👍
Stay tuned..............
scooterslag
Tue Dec 04, 2018 7:18 pm
Bit wild looking 8-) skipper/typhoon engine?
The mack daddy on the left!
Wayne Miller
Tue Dec 04, 2018 8:34 pm
The engine set up uses a set of Malossi C-One cases that are based on 50cc Piaggio style cases. They’ve been machined to accept a larger crank and bore so now 98cc. All the kit in there ie crank, gearing and transmission is top spec. I’ve opened up the reedvalve too and used a CR85 vforce 3 reed set up with a 38mm airstriker. The cylinder and pipe are both supplied by Roost but the cylinder has had some additional work done to it to make even more power. It’s not been dynoed yet but it should be somewhere between 35 and 40bhp.
The Alunium frame is made by a company called Kiesler but I’ve modified that too as I have used a wide rear dragster tyre and had to move the engine over to centre the rear wheel, it still need to be welded. I hope to have it up and running this weekend and completed just after Xmas
Wayne
Wayne Miller
Tue Dec 04, 2018 8:52 pm
Heres a few pics of the rear wheel set up
Wayne Miller
Tue Dec 04, 2018 9:30 pm
Found a seat pod of a GP race bike that I liked, I had to make a couple of holes in it to get it to fit
I don't like the front bit so need to modify that and also get my aluminum seat and tank hidden underneath
Wayne Miller
Tue Dec 04, 2018 9:38 pm
Front bit removed, hole for tank cut out and holes filled in, I just need to make it pretty now :)
Wayne Miller
Tue Dec 04, 2018 9:39 pm
Thats about where I am to date, more pics to come :)
Wayne Miller
Tue Dec 04, 2018 9:54 pm
Next Job, Get a temp spacer made to fill the gap left by moving the engine over. Luckily I have a mate in Holland that has an interest and he has made and posted the exact thing for the job :) Should be here tomorrow
holty
ebay user ID: amholt123
Main scooter: lambretta gp
Tue Dec 04, 2018 11:07 pm
wow that is going to be quick, love the rear tyre, some good work there, keep the pics coming, where are you going to sprint it ?
scooterslag
Tue Dec 04, 2018 11:10 pm
wow! spot on- love the pipe and back wheel set up 8-) . Paul
