RT 225 gearing
purple_pill67
Main scooter: Jet200
Spaniard wrote: Wed Oct 31, 2018 12:40 pm I have the same set up , only the 28 mm delly , with a jet 200 gearbox , 4.82 gear ratio
great stuff !
What sprockets do you have?
I have the same with 16/46 but felt abit flat in 4 th after going from a v2 to v4 clubman.
I'm just going from 58/110 to 60/110 crank, not sure if this will help or i still need to go back to 15/46
Leo
4.7 will be good. I tested that on mine initially and it was great fun on the back roads but ran out of legs at about 65mph on the motorway.
I have a 110x60 crank, LTH reed a BGM pipe and 30 PHBH carb
Spaniard
Main scooter: lambretta jet 200
purple_pill67 wrote: Sun Nov 04, 2018 10:38 pm
great stuff !
I have 15/46 sprockets
Mrnice71
I would go for 4.8 final drive 19 x 46 sprockets . Leaving the gearing at 5.2 will not utilise the power gains from the kit giving you no more top speed .
Fux
Main scooter: li150 S2
Ok. I ended up buying a 19 sprocket and 46 clutch, so 4.8 it is
Mrnice71
Good choice , and your still using an 82 link chain
    Users browsing this forum: Semrush [Bot] and 19 guests
