Cracked casing
garry inglis
Crank installed maghousing and stator back in ImageImage
garry inglis
Drive sprocket and clutch and pull down back in Image
cgt75b
Main scooter: lambretta
Has it been welded?
garry inglis
No this is a new casing
cartmel808
Looks like your enjoying yourself there Garry.
Minority
Main scooter: Li230 S3
Is it my imagination Gary, or does the mag side silentblock look as though it’s not all the way in?
Grumpy225
Looks about 2mm out of where it should be.
garry inglis
There's some eagle eyed amongst us on here yes it is I don't no weather it's the casing or the mount but the f@@ker won't go in I'll have another look at it
garry inglis
cartmel808 wrote:Looks like your enjoying yourself there Garry.Image
Hi cartmel 808 I am all this started with no back brake bloody lambretta ImageImage
garry inglis
Sorted the engine mount the chamfer on the casing was not machined properly so dremmel that and now sits in correct top end built up air leak test next and timing check with the buzzwangle ImageImage
    Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
