Cracked casing
garry inglis
In workshop at 6am must be mad on with engine mounts so I can get it on my standImageImage
garry inglis
Then the layshaft and gear selector Image
garry inglis
Then my li150 gearbox and endplate shimmed upImage
garry inglis
Love these new 4mm stainless sealplate studs and lock nut from Mike at torbay lambretta less than £3Image
holty
Main scooter: lambretta gp
nice work garry, exhaust port is a nice shape, i little bit of grinding to be done, keep at it matey.
garry inglis
I thought you might notice that
johnny650
Main scooter: lambretta 64 li 150 Special
cracking start today garry. Did you get the case welded in the end or are you using a spare ?
Do you use any threebond on the drive side halite washer ? I have nightmares about leaking drive side seals
garry inglis
Hi I bought another casing a new Indian 200 as I couldn't get a response on welding and I have 3 offers now so I will get that fixed and I don't put threebond on the drive seal just a smear of grease and tighten it up I've got all that done today will put dome more pics up
garry inglis
Casing matched to barrel Image
garry inglis
Driveside bearing in and mb plateImage
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
